FS: New S13 Megan Street serious and s13 Ksport Kontrol Pro Coilovers
Im locate in SoCal, I have 2 sets of coilover for sale
Both are Brand New taken out the box for picture only!!!!
1) Megan Street Serious Coilover kit for s13
Brand New
Local pick-up 780, 820 shipped
(paypal or money order) If paying with Payapl must be Comfirmed Address!!! ONLY ship the item to Comfirmed Address
Spring Rates: 8kg Front and 6kg Rear
32 Levels of Adjustable Damper
Pillow Ball Upper Mounts.
Rubber Dust Covers.
Adjustable Ride Height
Aggressive Spring Rates
Single-Cylinder Design
Aluminum Brackets
2) Ksport Kontrol Pro Coilover Kits for S13
Brand New
Local pick-up 750, 800 shipped
SPRING RATES: Front-7/392 Rear-6/336
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology featuring its 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Ksport Kontrol Pro Coilovers Feature:
- 36-way adjustable dampening
- Made from high quality 6061 Aluminum with T6 for increased hardness
- Compression/Rebound adjustable
- Adjustable spring perch for height adjustment
- Adjustable body allowing maximum suspension travel
- Pillow Ball Top Mount w/ adjustable camber (not available for some models)
- Monotube High Pressure Design reduces oil leakage
- Electroplated body for protection from corrosion and rust
- One Year Limited Warranty
Need more info on the coilover please ask, also if you need more picture i can prove thank you.
Brand New
Rubber Dust Covers.
Aluminum Brackets
Brand New
negatory. s13 fronts will fit on an s14 only if you enlarge the diameter of the hole for the bolts to pass through for them to bolt onto the spindle. the rears of an s13 are taller than that of an s14.
bump. I'll see if my buddy has funds for a set of these coilovers
BlackZenki82
02-27-2009 07:37 PM
