S14 PART OUT interior panels, trims, molding, steering wheel, trunk set, console etc.
Left over interior pieces from 1996 and 1997 S14 parts cars
If you are looking for an interior part and it is not pictured here I do NOT have it.
Reasonable offers welcome.
The more you buy the better deal you get.
Shipping is extra.
Clean steering wheel, airbag and cruise control buttons *NOT* included SOLD
Full trunk carpet/panels set SOLD
Sunvisor pair (yellow label) SOLD
Sunvisor pair (orange label) SOLD
Sunvisor clip w. good screw mount SOLD
Fuse panel w. door SOLD
Fuse Door SOLD
S13 shift boot good shape $25
S14 5 speed shifter trim w. NEW replacement boot $35
Dead pedal $5
Full jack kit w. crank & lug wrench & tool bag $40
Rear view mirror $20
Ash tray $30
S13/S14 Zenki seat recline lever (not in picture) $5
Glove box w. latch, lock & frame $25
Rear seat latches / pair $5
Door open latch left & right $10 each, trim for right SOLD
fuse box lid $10
dash side vents / pair $15
door finisher triangles /pair $10
Dome light complete SOLD
Dome light lens SOLD
Steering wheel side trim $5
Throttle Cable $15
Steering column clam shell SOLD
manual / fixed antenna mast & mounting base - lets you delete your broken power anttena $30
door sills / pair $15
ecu cover kick panel $10
Passenger door pull switch panel (switches NOT included), SOLD
Passenger door switches $25
Driver door pull switch panel SOLD
fuel tank lid "screw down" $10
Zenki USDM front license plate bracket $15
rear charcoal seat belts /pair $25
lower door rubber molding/gaskets $5 each
Speaker mounting pods / pair SOLD single unit $10
full a pillar trim with factory tweeter grills / pair SOLD
behind back seat 3 piece finisher set $20
rear window finisher $10 each
gauge cluster finisher trim without dimmer switch $20
sun roof opening headliner trim $5
cabin to trunk pass through trim S14 $5
cabin to trunk pass through trim S13 $5
trunk weather strip / gasket $10
Center console w. lid, no switches $20
Hood prop S14 bottom $15
Hood prop S13 top $15
Hood hinges S14 / pair $35
Shipping is extra.
Fuse Door SOLD
Dead pedal $5
Ash tray $30
fuse box lid $10
Throttle Cable $15
Cliff2286
11-05-2007 06:16 PM
Indolent
06-11-2007 09:16 PM
Bryan
01-24-2006 12:54 PM
SEXXXYSliDE
11-26-2005 07:49 PM
