FS: Car audio amps and subs
Old 09-22-2008 | 01:00 AM
Asneer's Avatar
Up for sale I have a bunch of my audio equipment because a car is more important than audio (and I need to pay off the rest of the 240 fastback I just put a down payment on). So please help me out!
Eclipse XA4000 Amp... Basically this is a kick *** amp that has plenty of power for your high end. I have 2 component sets that it drives, and it sounds awesome. Its also a class D amp. I have had it for about 2 months now.
ICEpower technology—full range Class D power
Highly efficient FET power supply
Variable 30-500 Hz 18 dB high-pass crossover
Variable 50-500 Hz 18 dB low-pass crossover
Variable 0-8 dB Bass Boost
Fully variable Subsonic Filter from 32-64 Hz
Illuminated Eclipse logo power indicator
Clipping indicator LED
Multi-Channel Amp SpecificationsAmplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 125W x 4 @ 14.4V
@ 2 ohms 175 x
THD at 4-Ohm RMS Power: 0.05%
Bridged RMS Power @ 4 Ohms: 350W x 2 @ 14.4V
Speaker Level Inputs: no
Preamp Outputs: yesBuilt-In Crossovers: HP/LP
Bass Boost: 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >90 dB
Fuse Rating: 3 x 30 amps
Asking $350 shipped OBO
I have a pair of Ultra Linear 12" Subwoofers (bigger 12's with dual voice coil and cast frame). Very loud when you want them to be but very punchy for rock music. Put them in a sealed box, and your good to go.
*These are NOT the ****ty stamped ones you see on ebay.
UL120 DC
2.5” 4-Layer ASV Voice Coil
RMS: 400 Watts
Peak: 800 Watts
Magnet Weight: 150 Oz.
F/R: 25Hz – 2500Hz
Fs: 31.09Hz
QMS: 3.01
QES: .47
QTS: .41
VAS: 90.05
REVC: 1.7
SPL @ 1w/1m: 92dB
X-Max (linear peak-peak): 22mm
LEVC@ 1k Hz: 1.39
Sealed Enclosure: Min .75 Cft 3dB down point: 58Hz
Max 1.0 Cft 3dB down point: 55Hz
Vented Enclosure: 2.0 Cft @ 40 Hz 3dB down point 38 Hz
Port Diameter: 3"
Port Length: 14"
Number of Ports: 3
Port area: 21 sq in
I had them in a sealed box and they sounded great, then I made the custom vented box to the specs, and they sounded amazing.
Either way, if your looking for good bass, then these are great. If your looking for clarity and punchy-ness then you want to just do a sealed enclosure.
Asking $80 a piece or $140 for the pair shipped.
Kove audio 2400 AD Armegedden mono amp.
(Don't even look for these on the internet, because they don't exist anymore)
I have had it for almost 2 years, and its easily the best bass amp I have ever had. I got it for $580 back then and they MSRPed for $799.
It is a perfect match for the ultra linear speakers i have found, and a very loud combo at that.
SOLD!
I really need the money to pay for the rest of the 240 fastback I just put a downpayment on so please help me out!!
Let me know.
-Andrew
Old 09-24-2008 | 04:18 PM
Asneer's Avatar
Bump! because the Kove amp is sold!
AND
Ill sell the Eclipse amp for $315 shipped.
Old 09-24-2008 | 04:19 PM
Asneer's Avatar
If your skeptical about my feedback, you can look me up on ebay and rs25.com. My username is normally AWSneer.
Old 10-05-2008 | 12:39 AM
Asneer's Avatar
Last bump.
Eclipse amp for $295 shipped
Yanman233
09-07-2006 06:29 AM
EC.240
03-30-2005 10:20 PM
nismosileighty
03-20-2005 02:29 PM
burningskulls
11-02-2004 12:07 AM
partyb0y69
02-16-2004 02:58 PM
