'For Sale' Exterior / Interior / Electronics Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components.
Sun Auto Is Here!!! More Gas!! More Power!!!
Old 07-12-2007 | 03:26 PM
Kami Speed's Avatar
**PM FOR PRICES** FREE EXPRESS SHIPPING!!!
Benefits:
Increased engine response.
Improved fuel efficiency.
Increased horsepower.
Increased torque.
Reliable ignition spark throughout the entire rev range.
Reduced emissions.
Stabilized idling.
Introducing CYBER SPEED
Cyber Speed components are created through development of technology used for competition with the record breaking Cyber Evo. Now, the benefits of our experience with racing technology are available for your vehicle, so you too can feel the competitive spirit of CYBER SPEED.
Introducing Hyper Ground System
The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation.
Introducing HYPER Voltage System
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
Introducing HYPER Force System
Thy Hyper Force System is the next generation high-efficiency ignition tuning and strengthening system. It works by absorbing all back electromotive force, which aids to improve plug voltage and promote complete combustion by producing 100% coil efficiency. Also, the Hyper Force System eliminates any ignition performance loss due to decreased electrical current under heavy throttle. Since ignition efficiency over the entire revolution range improves, available torque and acceleration response improves: this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emissions
Introducing Hot InaZama Pocket
The Hot Inazma Pocket is a revolutionary product which helps to tap out the full potential of your vehicle. It provides an extra boost to the electrical system when accelarating, using the A/C, using the radio, and when the lights are on. The Hot Inazma Pocket also stabilizes the electrical system and helps stop unnecessary elecrical usage thus reducing emissions and increasing fuel economy.
Introducing InaZma Eco Blue
By simply connecting Hot InaZma ECO to your battery, you can your electrical system to operate at peak efficiency. Air conditioning, stereo, lights, and many other electrical components in your vehicle are constantly creating a load on your electrical system. This causes fluctuations in voltage which prevents the vehicle from performing at optimum efficiency. Hot InaZma ECO is designed to stabilize battery voltage for enhanced electrical system efficiency, allowing your vehicle to operate at its full potential.
Introducing InaZma Hyper Gauss
The Sun Auto Hyper Gauss is a magnetic fuel regulator enhancer that is designed to burn fuel more efficiently. Using powerful magnetic force to break down fuel particles to burn more efficiently, improve gas mileage, better throttle response, increase torque and horsepower.
Rollnnn
West Coast/Hawaii
04-11-2012 12:31 PM
201Motorsports
05-15-2008 10:11 PM
driftfactory
11-11-2004 07:18 PM
sleighty
04-03-2004 01:23 PM
OWU Joe
01-29-2004 12:18 PM
