The All New PLX DM-200, DM-5, DM-100, SM-AFR, R-300!
Please visit this link to order:
http://streetrays.com/plx-devices/b-10423.aspx
PLX DM-5 SM-AFR Gauge Combos in Black or White Face! $256
Other matching PLX DM-5 52mm Gauge/Sensor:
PLX DM-5 Air Intake Temp + SM-AIT
PLX DM-5 Boost + SM-Vac/Boost
PLX DM-5 EGT +SM-EGT
PLX DM-5 Oil Temp + SM-FluidTemp
PLX DM-5 Water Temp + SM-FluidTemp
Not into having a dash full of gauges? How about having up to THIRTY TWO different inputs all through one remote controlled gauge?
PLX iMFD DM-100 Display for only $246
Use all of your existing daisy-chainable SM sensor modules, or save money on upgrades in the future since you'll only need the sensor modules. Tailor the fully programmable OLED display to match your factory gauges or interior theme!
The all new DM-200 OBD2 Plug in for an easy 10 second installation! The following is also available NOW:
Email : sales@streetrays.com
Phone: (512) 989-RAYS (7297)
We are open for direct contact Monday-Friday 10AM - 6PM CST.
I don't know to much about the PLX DM-5 COMBO. Can it data log? Also what is the sample rate? Can it convert wideband to narrowband for the ecu? Would I need an additional bung?
What sensor type does the PLX DM-5 use, NGK or bosch?
Is the PLX 100 for OBD1, and is the 200 for OBD2?
Sorry I'm full of questions for the consumer.
sm-afr doesn't datalog, r-300 is the current datalogging wideband unit from PLX.
you should get sm-afr + dm-5 combo for $256 and it comes with everything except the O2 sensor bung. it uses bosch sensor. it outputs narrowband, yes. and it uses critical response tech. please visit: http://www.plxdevices.com/products/sm/afr/
streetrays
06-11-2008 12:43 AM
