jdm r33 Gts-T rb25det swap f/s
Old 08-16-2003 | 12:42 PM
racer98's Avatar
Post jdm r33 Gts-T rb25det swap f/s
JDM r33 skyline gts RB25DET (280hp) R33 Skyline motor swap for sale complete also has ceramic turbo complete change Complete motor with turbo, original full harness, ECU, mfs, cas, 5-speed gear box with drive shaft from original Z31 200zx~R flywheel, used clutch, starter, alternator non-hicas power steering pump over a/c and lines also have harness diagram pin outs from an English service manual for the RB25DET for a swap over into a us-spec s13 or S14 also this motor comes with the Z31 200zx~R skyline oil pan and the motor mounts and crossmember. $3500 Compression is 170psi on both motors and leak down is 5 f you need more info give me a call (818)-345-7289
Attached Thumbnails jdm r33 Gts-T rb25det swap f/s-r33.jpg
Old 08-22-2003 | 08:48 AM
Mr.Apple's Avatar
Where are you located>?
Old 08-22-2003 | 12:59 PM
rudeboy's Avatar
info like that usually helps
Old 08-25-2003 | 01:39 PM
Mr.Apple's Avatar
Where you at Racer98??
Old 08-25-2003 | 02:37 PM
runyun's Avatar
He's in Encino, California - I believe by Burbank.
Old 08-25-2003 | 02:43 PM
runyun's Avatar
BTW - if you plan on buying from him, make sure it's in stock.
other than that - his motor's are of SUPER quality. Even the panels I received looked brand spankin new.
If the fenders I got didn't have the stock sidemarkers on them.. I would honestly have thought they were brand new from the dealer.
Old 09-01-2003 | 04:51 AM
NightXCZ77's Avatar
RB25DET only has 250 hp, not 280...just thought I'd put that in.
Night
Old 09-01-2003 | 06:04 PM
Driftin RPS13's Avatar
is that 3500 shipped? if not how much would shipping be to Green Bay WI 54301? i am very interested!!!!!!
Old 09-05-2003 | 09:00 AM
runyun's Avatar
NightXCZ77,
You're the guy people are talking about in this post right?
http://www.nissaninfiniticlub.net/fo...threadid=26728
if so, you've made a lot of people upset
linnboi
08-16-2010 07:25 AM
otterball21
07-16-2007 11:03 PM
201Motorsports
04-04-2007 03:55 PM
vutoneh
02-19-2006 09:38 PM
NightXCZ77
02-23-2003 02:01 AM
