hks gt2540r / gt2871r
I have an hks gt2540r turbo for sale this is a direct replacement for the sr20det. it is very comparable in size to a gt2871r.
The HKS GT Series Turbos are based on ball-bearing Garrett units and like the HKS Signature Series have re-engineered compressor and turbine wheels along with specific A/R and trim levels. All GT Series Turbos are designed to be a perfect blend of power and response. HKS achieved this balance by first choosing to use a ball-bearing center cartridge to reduce friction along with an off-center turbo design for improved efficiency and flow. Next HKS carefully tested Trim and A/R levels along with different inlet and outlet diameters to achieve optimal power. The results of this combination are turbos that not only deliver amazing power, but also spool incredibly fast.
COMPRESSOR: gt2540r
-Wheel- 46 Trim - 51.7 Inducer / 76.2 Major
-Housing- 60 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25 inlet / Internal GT25 oulet - 0.64
-Retail- $1980
GT2871R
Ind Exd Trim A/R
49.2mm 71.0mm 48 0.60
Wh Dia Trim A/R Type
53.8mm 76 .64 Wastegated
only $800 call chris @ 903 530 9214 or email me at williamcvm@yahoo.com
HPIM0841.jpg?t=1284758737
HPIM0842.jpg?t=1284758775
HPIM0843.jpg?t=1284758692
COMPRESSOR: gt2540r
TURBINE:
-Retail- $1980
GT2871R
Ind Exd Trim A/R
bs280
04-14-2008 02:57 PM
bs280
02-07-2008 04:24 PM
yektik99
02-04-2006 11:38 PM
