PostRelease Archive Industry news and announcements direct from manufacturers and vendors.
Tire test results for Nitto Neo Gen
Old 12-18-2007 | 08:01 PM
PostRelease's Avatar
Former Sponsor
Nitto Neo Gen
Recently a leading consumer magazine tested all-season ultra-high performance tires. Nitto's Neo Gen tire
received second place overall with the editors commenting that the Nitto Neo Gen had basically tied with first
place.
Fifteen tires from several tire manufacturers were tested in nine categories, mainly focusing on dry handling and
traction, wet handling and traction, and ride comfort. All tires in the test were sized 225/40R18. All tires were
tested using an Audi A3 3.2 on a closed test course. This data was combined with results from independent tread-wear
testing which evaluated tread wear up to 12,000 miles.
The Nitto Neo Gen had a strong showing in all tests. The Neo Gen received a ranking of Very Good in both
dry and wet braking and Good in both dry and wet handling and hydroplaning. The Neo Gen also received high
marks for noise, ride comfort and rolling resistance, scoring Very Good for all categories. The Neo Gen was
also one of the most affordable tires tested. Because of the Neo Gen's balance of dry and wet performance, and
ride comfort, the editors recommended it as one of their top picks.
For sizes and specs on the Nitto Neo Gen tire, click
here.
Features:
  • The inner shoulder is made from one continuous block, which adds stability and prevents tread flex. By
    preventing tread flex, the tires wear more evenly, even on cars with negative camber.
  • The large outer shoulder blocks are designed to optimize the surface contact and provide outstanding corner
    traction.
  • Deep circumferential grooves work with the slanted 3D tread blocks to evacuate water to help maintain contact
    with the road and provide excellent wet traction.
This PostRelease(tm) is part of an advertiser-supported program that sponsors Club 240. This program delivers relevant news and announcements as posts within the Club 240 forum.
StarScream_s13
01-21-2006 04:32 PM
240sxgone
01-01-2006 09:16 PM
nisilvia
12-01-2004 12:06 AM
PANGES
06-23-2004 12:01 AM
