Ticking noise in head...
Old 04-20-2007, 07:14 AM
FuriousZ's Avatar
1. Is this the top chain guide that can be removed safely?
2. Have anyone of you had any problems when removing the chain guide?
3. is it only two screws holding it on?
4. should I replace the screws or leave them off?
Thanks
here is a pic.
FuriousZ is offline
Old 04-20-2007, 09:10 AM
epp_b's Avatar
There is a ticking noise in my head when I get to 3000-3500rpm,
You should see a doctor about your hearing then
Sorry, couldn't resist
epp_b is offline
Old 04-20-2007, 01:00 PM
FuriousZ's Avatar
Thanks
here is a pic.
can someone please second that ^
thanks
FuriousZ is offline
Old 04-21-2007, 02:25 PM
cronux's Avatar
yes, it can be removed safely, it has two screws, you can either take them out or leave the screws in. i put mine back in, but in raines guide, it says just leave em out. doesnt matter, i guess.
cronux is offline
Old 04-21-2007, 03:09 PM
Originally Posted by motegineon
prolly ur chain guide, just remove the top one
Originally Posted by re037
prob valve tap, adjust shims.
i don't want to be the party popper but the "89 sohc doesn't have a top chain guide like the dohc nor does in have latch adjusters.
most likely it's your lifters. i don't know about sea foam i've never used it but if you do and leaks occur it will probably be from your front main seal which is not hard to replace.
jramosthe1st! is offline
Old 04-23-2007, 01:34 PM
FuriousZ's Avatar
I ve removed mine . . . IT DIDN'T GET RID OFF THE TICKING NOISE around 3K rpm...
I don't know what to say.....
FuriousZ is offline
Old 04-23-2007, 06:51 PM
might be the chain slapping or stuck lifters.
Old 04-23-2007, 07:43 PM
FuriousZ's Avatar
keep in mind that its only at 3k rpm
and by what i chekd the chain is on tight.
the chain guide didn't have any signs of rubbing or hitting by the chain...
... just FYI
enrique
FuriousZ is offline
Old 04-26-2007, 10:10 PM
now that i think about it i knew a guy with the same problem. i don't remember all the details but i think it had something to do with the egr valve and solenoid or bmp valve and solenoid.
Old 05-02-2007, 07:43 PM
killerk240sx's Avatar
hey man just so you no you cant do any adjusting on the valves they got hydrolic valve lifters so no adjustment but my car did the EXACT same thing at same rpm and everything if seafoaming it doesnt work didnt for me i tried you need to change the lifters if its possible to see which one is bad than you can just replace it. pull off you valve cover and rocker arms and push each if one is squeshy than it needs replacing they are about 50 bucks a peice god luck man hope it works out for ya.
killerk240sx is offline
Old 05-02-2007, 10:40 PM
  #26
or......you could try this
www.n-icoclub.com/articles.php?id=215864
click on the "link" remove the dash between the n & i hit enter
or this
http://www.courtesyparts.com/nms/s13/s13_1.html
or this
http://www.hybridka.com/sohccustom.htm
note to mods and admin
if i'm braking any rules by posting links to other 240 sites let me know and i'll delete them myself.
Old 05-16-2007, 07:32 AM
  #27
FuriousZ's Avatar
follow up. . . .
I fixed my LOOSE TIMING CHAIN and a ratteling noice ! !This week end I performed a good cleaning to my engine. I Seafoam 'ed it. Put 1/3 of a bottle in my oil, 1/3 intake, 1/3 gas. drove it around the block, idled it for a while. let it rest for a day, idle it some more. then i changed the oil. I took my time (all day) to drain the old oil. I ran about a quart of new oil to push down the old oil out. I took off my valve cover and poured some oil through the timing chain while pushing in and out the tensioner. You can hear it squirt oil out. At first it was hard to push in but i worked it for a while and got it moving.
I filled it up with fresh oil (synthetic blend 10-40), fresh filter, fresh spark plugs, fresh valve cover gasket, and fresh gas filter.
It ran good!
THe timing chain didn't make the noise it made before, and it was nice and tight.
I even reduced (to almost gone!) a rattleing noice at 3000 RPM. I was guessing it was a sticky valve and now its almost gone.
I am extremely happy!
I even painted the valve cover!
enrique
FuriousZ is offline
smoken805s14
04-21-2009 12:10 AM
tonyfizzle
10-01-2006 12:50 AM
MacDru
03-12-2006 09:10 PM
Unholy FD3S
07-13-2005 10:23 PM
junk240sx
05-11-2004 01:25 AM
Quick Reply: Ticking noise in head...
