tach acting up
Old 12-10-2007 | 12:57 AM
alindeman1989's Avatar
tach acting up
my tach will not go past 3 grand on my stock 96 240sx. the tach gets to 3 and just stays there or kinda bounces. what is this and how can i fix it?o and its the original tach
Old 12-10-2007 | 02:34 PM
anyone?
Old 12-10-2007 | 03:13 PM
k_wakasugi's Avatar
is it just the tach, or will the engine not rev beyond 3k?
Old 12-11-2007 | 01:37 PM
its just the tach.
Old 12-11-2007 | 03:40 PM
Try pushing in the connections better, or try a different tach. Or hit the insturment cluster.
Old 12-11-2007 | 05:52 PM
k_wakasugi's Avatar
also try yelling at it while you hit it. that helps.
no but seriously, i had a problem similar to this, i took the cluster out to inspect, i unplugged/replugged connections, then never had a problem with it again. so i suspect that it was just a loose connection. good luck.
Old 12-15-2007 | 06:58 PM
SmokedZenki's Avatar
i have had problems with my tach as well. but mine works whenever it wants too. some days it works some days it doesn't. and it has been doing this ever since i changed my clutch?? i thought maybe it has something to do with my flywheel sensor located at the top on my bellhousing? so maybe this could be your problem too? im not really sure tho?? sorry i couldn't be more help..
Eric
smokey240sx
01-24-2005 06:33 PM
ehxtahcee
10-12-2004 11:36 PM
240fstbk
11-07-2003 11:48 PM
Amolao
06-05-2003 05:49 PM
S13Nissan240SX
04-22-2003 03:59 PM
