swapping a ka24de into a 90 240sx...
Old 11-23-2005 | 07:12 PM
nissansileighty's Avatar
i don't know if this has been mentioned before here. I am planning to do a ka24de swap into my 1990 nissan 240sx. i want to ditch the sohc and go with the dohc engine. it seems pretty strong and has alot of potential. i just want to know what i will need for this swap. i heard that both engines shared the same bottom block and transmission, but im not sure. any suggestions would be great!
Old 11-23-2005 | 07:23 PM
http://www.zilvia.net/faqs/archive/SOHCtoDOHC.asp
Old 12-28-2005 | 05:35 PM
islander11's Avatar
link's broken?
Old 12-28-2005 | 06:11 PM
soldierdude262's Avatar
I seem to remember someone posting on here that you can just swap the heads, unless the newer motor has less miles but otherwise a head swap would be easier.
Old 12-28-2005 | 07:30 PM
Originally posted by islander11
link's broken?
Zilvia's in the process of an overhaul so it will probably be down for some time, I will try and find the info again.
Old 12-29-2005 | 04:32 PM
jad240sx's Avatar
well i did the same thing a year ago and if i remember right i just changed the ecu and the harness the power steering is on the oppiste side and the ac lines are to so you have to make them longer. other than that i cant think of anything else right now.
Old 01-02-2006 | 10:11 AM
usdm240's Avatar
you will need:
-engine (complete with MAF, pipe, etc.)
-harness
-ECU
-power steering lines
-custom A/C lines
SOHC tranny are the same. its a yank out and drop in thing. i have done many single to dual swaps in less than a day.
Old 02-10-2006 | 10:51 AM
Divisione_240sx's Avatar
ya, im looking to swap my SOHC to the DOHC then build it up from there, mainly for drifting. is it really true that you can use the same block?
Mr. 240
Old 02-20-2006 | 06:16 PM
Phatmax98's Avatar
I have a question for this thread as well, I have an 89 240sx and am getting a 95 240sx engine, does it matter what year the ECU is? I'm thinking 95-98 ecu's are the same but I am not for sure. Thanks
Race_bred
RB
09-26-2009 07:00 AM
jackyliem
03-26-2007 11:12 PM
jackyliem
02-15-2005 01:46 AM
bluebox
09-30-2004 04:33 PM
marqSR20
03-08-2004 10:07 PM
