sr fuel rail on ka
sr fuel rail on ka
I'm thinking of getting a sr fuel rail with the injectors. Because 1 of my injectors is leaking gas and it reeks of it. Is there any possible way to make the sr fuel rail fit onto my ka motor? And is there any possible way to have to avoid soldering the wires together? Or is it sure that soldering will be involved?
I won't have to solder wires, however I do it, right? I can't solder at all. I asked my brother cuz I know he soldered his but he says he doesn't know. But he had his wires cut. If I get uncut wires they can just be plugged and play? Or whatever...?
unless you or some one else have cut the
connector off of your harness all you do is dissconnect your leaking injector, remove the injector then replace with new injector
and reconnect the connector. thats it no soldering involved unless like i said above
you or some one cut the old connector.
if you did i dont know why???
asr702
12-04-2004 02:36 PM
