rear bumper melting
rear bumper melting
ok since i gotten the car up and running i have no problems at all..butt after ahile my rear bumper is coated with black sute, and melteing,
also it back fires on idle butt i think thats b/c i have ****ty plugs in it and havent changed them since i got it running, also i replaced cap rotor and wires ext and have no vacume leaks, runs fine all day with no problems
i like to fix this issue and have a clean rear end.
its a single cam if ur all r wondering AND i have no ecu codes at all..
can it be my o2sensor?
any ideas
also on a side note i would like to convert to power windows, ill be getting the doors and wireing to it. is it a simple plug and play or am i gona have to run wires?
buddy of mine is partying out his 240 and i got first dibe..
any ideas
back fire can come from any component in the ignition system
coil
dizzy
wires
plugs
etc
all of it has to be on the same page bro no if and or buts..
check all that out and come back also you may wanna run and ecu diagnostic that could tell you something.. if you don't know how to do so, check out the how-to section for help with that.
coil
dizzy
wires
plugs
etc
iv done a compression test and read 200 across all cyclenders.
i am wanting to say it might be my plugs cuz they are auto lites and i just havent had time to replace them yet.
i also did an ecu diagnostic and no codes come up so i kno thats all good
butt what about the o2 diagnostic, well idk cuz i cant seem to figure out how to read that setting
it is a single cam
well it got alot worse it does turn out i have ablown head gasket and just in the nick of time i was just givein another motor for free
another single cam, so i plan to do the swap tonight, and as for the bad motor im gona build it up abit
forged pistions, rods, port and polish head
any other mods i can do to a single cam so later down the rd i can boost it?
MAD240SX
07-20-2018 11:38 PM
ToyoSupraR
06-03-2006 02:39 AM
