really thinking about rebuilding KA
Iam not having much luck with this sr20 situation, iam thinking of just rebulding the KAde. What should i consider replacing, and what parts / mods can give me some actual hp increase??
Balanced rotating assembly, cams, port/polish head, higher compression pistons.
You'll have a hard time getting near 200hp n/a, and the higher the total output, the more 'peaky' the motor will be. Just the way it goes n/a, when you start getting to higher specific n/a outputs, you start moving your torque peak higher in the rev band and lose 'area under the curve.'
You're going to end up spending some cash on the machining and assembly unless you can do it yourself. Not trying to discourage you, but you may be able to put together a low psi turbo setup for the same money as an n/a buildup and end up with a more driveable engine.
-Justin
-Justin
Don't things start to get expensive at that boost level?
I know that people have run 7 on stock injectors and bottom end. Iactually think there's someone in the New England area running 10psi on stock bottom end and injectors.
5-7psi can be done on the cheap without ripping apart the motor. Once you get into rebuilding the block, your costs usually rush right past the cost of installing an SR.
-Justin
-Justin
-Justin
-Justin
SHIFT_Sideways
06-10-2005 12:53 PM
l2aine
26
10-10-2004 10:02 PM
DCTperformance
01-23-2003 07:29 AM
