O2 and door lock is bad
My 98' 240sx
Help!!!!!!!!!
1. My engine light came on about a month and a half ago, code was to replace O2 sensor.
Question:
- Where can I get a cheap O2 sensor? Nissan has a monopoly up here and well charge me an arm and leg
- Should I repace it myself? Looks very easly to acesess.
2. My Driver side door won't lock and unlock from the outside. It a pain, I have to unlock from the passenger side.
Question:
- Should I fix it myself, is it easy?
Help!
Help!!!!!!!!!
Question:
Question:
Help!
Well get a O2 sensor from advanced auto or someplace cheap like that. Pepboys carries botch. You WILL notice a difference in your idle and performance when you get a new one because it will even out your air/fuel mixture more since itll be reading correct. Also about your door, take the panel off and see if you can find whats wrong. Good luck
Robbie
Robbie
O2 sensor's can be found @ any auto store like he said, they'll offer you two types, a sensor with a universal end that you'll have to make fit, or the one that the wiring slides right in. Do yourself a favor, save the $10 and but the cheaper on, and buy a connector end and DIY.
With the door, could be a lot of things. Take the door off, see if it's mechanical or electrical.
Dr.
Dr.
Originally posted by evil98silvia
On your exhaust header. The o2 sensor is screwed into it. Unscrew, renew, cut, strip and crimp. You cant mess it up, dont worry.
Robbie
Robbie
Thanks
www.pdm-racing.com www.courtesyparts.com or go to pepboys or advanced. Botch is what I use. Doesnt really matter though.
Robbie
Robbie
I just went to the nissan Dealership (only one, small town monopoly) the they wanted to charge me $150 for a universal O2 insted of OE and $60 labor. I laughed and walked out.
I found one a autozone shipped for $80.
Thankx for yalls help!!!!!!!
JonathanRuiz
03-30-2008 12:40 PM
Chillin240
09-02-2005 06:51 PM
