New to K series
Originally posted by L20b-B110
dont have any new ones but will post some. once i find out how to.
Its not a show car by any means..but was in okish condition for a 34yr car.
1971 1200 datsun with piece of my old 1971 ford mk1 escort
Will post new pics when the car is completed.
Can a Lseries head bolt unto a Zseries block??? Is the Zseries engine good for N/a tuning???
If you go to MSN to the 720truck forums it better explains the problems involved......
NAPSZ is excelelnt for N/A tunning, but the NAPSZ head sucks.....
Use the SOHC KA head and you will be one happy guy....
Originally posted by BigVinnie
It can but then you just have the same coolant passage problems, that need retro fit.
Found a Z18 today for free so i just wanted to know.
That head work is SWEET man!!!!!!!!!!!!!!!!!!!!
Here is the 720 site with all the info you need on the conversions....
http://groups.msn.com/NissanDatsun72...sageboard.msnw
Here is the info on the NAPS-Z that you asked for.....
I highly recomend the use of the KA sohc head, just for it's crossflow head design, it will prevent vapor lock, unlike the L series head......
thanks...i haven't sourced a Ka24e head nor an engine, SO for the time being the Lseries head would give better performance than the zhead. Also the Z18 would allow me to rev a little higher and gain more power to 9500.
#26
But I guess if you want that high rev I would defenitely clover leaf weld the z18e head and also mill it down....
I think the CR on the NAPS-Z is around 8:3 or 8:6 depending on the size of it's displacement.
After all NAPSZ engines were strictly designed for smog emissions the lower CR would leave lower cylinder temps, allowing it too pass the smog......
You can probably get some performance from the NAPS-Z with it's cross flow design, but the head will need significant machining, and will also need titanium retainers, and springs for that high rev.........
I would like to know how your project turns out........
Keep me updated.....
#27
Is this the engine you have?????????
As you can see the additional spark plugs to the exhaust ports also interfer with the CR, it was designed for the purpose of burning out the additional NOX, before flowing to the catylitic.
If I were you I would use an L20b distributor, and remove all NAPSz equipment...
Also weld those exhaust spark plug holes shut.........
#29
the engine is in a FWD stanza. the distributor is in the head at the front on an angle. I hope this engine is a Z18 n not any other nissan 1.8.
I don't believe the NAPSZ was ever converted for front wheel drive use...
