misfire on cylinder 2
i just recently bought a 1993 240sx se fastback. It has a constant miss on cylinder2. I thought that the valve cover was leaking making oil cover the plug and boot which would result in misfire. so i replaced both gaskets (spark plug and cover) i cleaned out the head where the plug goes and the plug itself. I also bought all new wires and a plug for cyl2. still a constant miss on 2 (cylinder 2 has never fired since i have owned it)
I pulled the fuel pump relay and cranked it with #2 plug out and i have spark.
I am thinking(and hoping) that i have a clogged fuel injectior. I guess the easy was to figure this out is to swap injectors and see if the miss follows. I hope to god i have compression.l i woukd hate to have to pull the head, but if have to i will.
any thoughts??
any thoughts??
ok so i switched the #1 and #2 injectors and the miss followed to cylinder1. so i was sure that it was an injector. i found one at autozone for $87 so i went to my atm in my misfiring240(probably not a good idea) . when i got back to my car it started without the miss, and it drove all of the way home without it!! it even restarted!! so do you think i still have a faulty injector??
Dounveeme
16
07-10-2004 02:32 AM
