ka with spark and fuel no flame
Old 11-07-2009 | 02:14 PM
peng's Avatar
so i rebuilt my ka bottom end and obviously had to pull the timing chain and distributer off left the top end on marked the chain and the gear so i could match them after i had the new bearings in matched them up after i put everything in and now i have fuel and spark but no flame could i have messed the timing up???
Old 11-07-2009 | 02:53 PM
what happens when you turn the key? will the engine turn over or not, if so is it turning over too slow, too fast? if it's not turning over, are there any noises?..ect ect ect.
we need more info.
Old 11-07-2009 | 03:03 PM
peng's Avatar
spinns over just fine sounds a little slow but not enough to not start i here the fuel pump and everything start up. it has all new fluids tranny to and i have spark o i have a rogue plug on the intake side that i cant find the sensor for it is a 3 wire plug
Old 11-07-2009 | 08:00 PM
without knowing what sensor you are referring to, at this point the best i can figure is that your timing is off. you should set the engine to tdc and look over everything to make sure things are where they should be.
nschultz0124
08-15-2005 06:47 AM
240chz
27
05-25-2004 09:58 AM
irax
25
02-15-2004 08:38 PM
oxt3n
08-09-2003 11:05 PM
m2891e
02-24-2002 04:33 PM
