ignition problem
Old 01-01-2007 | 06:28 PM
rps13VEk's Avatar
ignition problem
I just put a new ka24de in my car and I have a problem. When i put the key in and put the ignition in the start postion, and then put turn the key into the off postion and remove it, the car's dash stays as if it was in the on position. I think it is the started relay. Problem is...i dont know where it is...If anyone knows where it is, or has an idea of what else the problem could be please tell.
Help would be much appreciated..thanks!
Old 01-02-2007 | 05:49 PM
rps13VEk's Avatar
ok, i forgot to connect 2 wires on the alternator...its fixed...however...
Now my car doesnt get spark....I've tested all connections and they're fine. If anyone has a trouble shooting guide for the ignition system (that tells you problem voltages and methods for checking them with an ohm meter) I would appreciated it....
Old 01-03-2007 | 08:13 PM
re037's Avatar
you can dl the fsm free. it is stickied somewhere in one of the subforums.
got_psi?
SR
04-24-2010 01:29 PM
240m3srt
10-05-2006 12:26 AM
nautica_t
02-26-2006 09:14 AM
