HOW TO: custom Individual Throttle Body install
Old 03-28-2007, 07:25 PM
  #31
1993240's Avatar
Thanks for the heads up. I appreciate it.
Okay, just so I'm straight. I would need everything on the posted list as well as a stand alone ECU or piggy back system in order to handle the amount of air/fuel being dumped into the motor, correct?
All together it would be about a $500-600 upgrade, right?
1993240 is offline
Old 03-28-2007, 07:34 PM
  #32
i honestly have not looked into that cost.. many of those are averages...
you don't need standalone at all bro.. safc will be fine.
Biggamehit is offline
Old 03-28-2007, 08:44 PM
  #33
yeah just something basic to get 'er done.
RuizXIII is offline
Old 03-28-2007, 08:58 PM
  #34
hmmm.... from the reasearch ive done with itbs ive read that you need to have a stand alone, a piggy back wont get rid of a maf. but then again mabey im wrong, lol i hope i am. i dont want to run a stand alone.
heres a link from ziptied http://www.ziptied.com/forum/viewtop...&highlight=itb scooter ftw
MS!3 is offline
Old 03-28-2007, 09:54 PM
  #35
BigVinnie's Avatar
You are correct sir....
An SAFC will do just fine, and there will also need to be an idle adjustment since the IACV is taken off from the other half of the mani. You can also implement the original nissan TPS onto the ITB. Who ever said you need standalones for this setup is crazy. Besides your ignition MAPS are set, all you need are adjustments in your fuel. FYI ITB's don't run to well without a plenum design for them, they run like crap with out it in hot or cold weather, you will need a plenum for the stock ecu anyway since using the stock MAF......
BigVinnie is offline
Old 03-29-2007, 04:18 AM
  #36
cool...
i seen an AE86 with ITBs with the injectors out side of the motor similar to indy cars.. that was NUTS.... watching the fuel get injected in at the different rpm levels..
now for that crazy setup im sure he utilized stand alone or some very good rom tuning.
Old 03-29-2007, 08:45 AM
  #37
1993240's Avatar
The only reason I asked about the standalone was a friend of mine is running IRTB's on his Miata with a piggy back set-up and he complains of a signal delay and that a standalone system will eliminate the delay. Is this not necessary on the 240 or is my not that intelligent on the subject?
After what I've researched and your guy's help, I think I'm going to stay away. My car is a daily driver and I don't need issues with weather. It gets pretty hot and humid in Florida.
1993240 is offline
Old 03-29-2007, 10:48 AM
  #38
??? meh, im kinda confused. with this setup hes not running a maf or a plentum. without a plentum you need a stand alone right? safc will only work if you use a plentum. you kinda threw me off.
MS!3 is offline
Old 03-29-2007, 05:02 PM
  #39
BigVinnie's Avatar
Sorry to throw you off. You need a plenum to run the MAF and stock ecu, no way to work around that. If you just want an ITB setup excluding a plenum then yes that is what you will have to do. Scooter finally moved up to a GT32 turbo set up so he had to use a plenum to run boost manifold pressure
Here is what it looked like. He now uses a haltech instead of a megasquirt standalone.
Old 03-29-2007, 05:25 PM
  #40
i see. i knew something wast right. scooters setup is so tight. oh and congrats on the mod spot. looking forward to more of your ka threads
MS!3 is offline
sage
12-14-2005 09:46 PM
Guam_Guy
07-15-2004 03:58 PM
DoriftoSil80
09-09-2003 03:46 AM
LHP
06-22-2003 10:16 AM
Strizzy
11-02-2002 12:54 AM
Quick Reply: HOW TO: custom Individual Throttle Body install
