help - key stuck in igition switch
Old 07-07-2004 | 08:14 AM
Topless's Avatar
hi,
the key to my '93 240sx convertible auto (5spd swap in progress) is stuck in the ignition switch (and yes, I tried pushing the button)... it came out once real easily but now it's stuck again and won't release no matter how I jiggle it or the wheel. any ideas? could this be an electrical problem or is it the switch itself?
thanks,
Ben
Old 07-14-2004 | 06:00 PM
nismo-drifter's Avatar
Try removing the casing covering the key ignition. There is a latch you can push against inside that should allow you to press the release button in further in efforts to remove the key. Found this handing trick in the owner's manual...Hope it works out!
Old 07-16-2004 | 12:17 AM
go S13's Avatar
It happened to me once. However, I replace the ignition switch, it is ok right now! Maybe, is the switch (looks like a big wire)!
Old 07-16-2004 | 03:33 AM
dkdeleon's Avatar
if its an auto move the shifter back and forth without removeing it from park untill it clicks , then try removeing the key
Old 03-30-2005 | 03:28 PM
redhorse64's Avatar
Yeah,
Mine does the same thing all the time...
So much, that now I am in the habit of hitting the Automatic Shifter forward, before ever even reaching for the key.
Kicked my butt for a while too...
Old 04-02-2005 | 06:40 PM
wikd240's Avatar
i would say the neutral safety switch was not bypassed correctly when doing the swap... on auto transmission equipped cars you cant remove the car without the transmission in park... if you have not bypassed the switch right you wont be able to remove the key... give all of your electrical connections real close to make sure nothing came apart or is loose...
Old 04-04-2005 | 08:04 PM
s13_peacekeeper's Avatar
did you unplug or take out the tranny with it in park?
Old 04-06-2005 | 03:09 PM
Krazyballa3's Avatar
my auto does the same... i have to push it forward into park before takign the key out... i m getting used to it... is urs a s13 or s14 auto
willywonka
06-30-2006 04:02 PM
redline88
01-17-2006 10:31 AM
jbird240sx
12-08-2003 09:01 PM
Drift_Ladie
11-12-2003 02:24 PM
