Help with connecting rod bearings : )
Old 07-12-2009 | 02:47 AM
dogdrinkincoffe's Avatar
I got minor rod knock and i wanted to change my connecting rod bearings first before anything and i dont know what size to get.
12111-53F00 0294 KA24DE STD GRADE 0
12111-53F01 0294 KA24DE STD GRADE 1
12111-53F02 0294 Ka24DE STD GRADE 2
what the hell is the difference between grade 0,1,2
Only my 2nd rod knocks and it only knocks at like 2.1k -2.3k rpm.
and at the moment i do not have money to do anything. I can only do this as a cheap fix until i get a swap.
thank you
Old 07-12-2009 | 07:17 AM
The grade of the bearing is the thickness. when you crack the block open you cant just slam bearings in there and be done with it if you want the motor to last
You must plasti guage the bearing seat to see what the tolerances are and use the appropriate bearing. If the tolerances are outside of the FSM specs, you either have to trash the crank or have it machined if possible.
most people just go with clevits bearings because they are thicker and the crank will wear them down to where they need to be.
ps
check around your area dude.. im sure you can find a KA for 100 to 200 dollars.
Old 07-12-2009 | 10:30 PM
please elaborate.
Old 07-14-2009 | 03:06 AM
like the other pistons are fine but the 2nd one. when i take out the 2nd spark plug and pull the throttle i hear no knock but when i put the spark plug back in and pull the throttle it makes the knocking sound. also when i drive the car on idle no knock once i hit 2.1-2.3k rpm it makes a small knocking sound then after than rev over it goes away
Old 07-14-2009 | 10:54 AM
it sounds more like pre-ignition than rod knock.
Old 07-15-2009 | 01:24 PM
then how would i fix that
Old 07-15-2009 | 03:44 PM
well, it depends on what's causing it. it's may or may not be a pre-ignition problem, i'm just going on instinct. but first, have you removed any of the emission components, and what you turn the ignition off, does the engine stop immediately?
Old 07-15-2009 | 04:05 PM
BigVinnie's Avatar
The clevits are a milder steel composition though. I don't know if they will last as long as the OEM bearings.
Clevit is a good aftermarket bearing though.
Grade 1 is usually a good bearing to go within tolerance, unless the damage on the crank is really bad, and has a signific ant amount of mileage on it. Always double check with the plastigauge though.
Old 07-15-2009 | 05:57 PM
roger that good info Vinnie..
RealDS13
05-24-2005 05:53 PM
Hamsterball
04-12-2005 11:23 AM
IAM-SO-sLOw
30
01-03-2005 12:04 AM
lanseri
10-08-2004 09:09 AM
irax
04-22-2004 06:00 PM
