Fuel pump problem on a S13 1991....
ok heres my problem...i tried starting my car but all it does is cranks. so i checked my fuse box and saw that my fuel pump fuse was blown. so i changed the fuse and it ended up getting fried again. so i put another fuse in and put my car to the on position and tried to listen for the fuel pump to turn on...come to find out its not turning on. so i figured since the fuses kept frying it might be the relay. I end up buying a new relay and installed it along with a new fuse. after that i tried again and still the fuel pump isnt turning on. i had this problem before but i dont know how i fixed it...i just checked the fuel pump itself and it started to work. but when i did the same thing, it didnt work this time....anybody have some suggestions on what to do or on what the problem might be?...thanks...James
nsn240
10-20-2006 10:50 AM
eastcoast240sx
10-13-2006 12:21 AM
