electric fan
if you look at the way the taurus fan was wired up with the Imperial Controller PN: 3647 $36 you can see that if the ac comes on it will turn on the fan as well... since you are removing your ac fan this helps with the cooling under ac load... if you also notice it is still wired to the temp switch... so when the temp comes up to temp the fan will kick on automatically... sounds like a smart way to do it to me...keep it automatic and there is no forgetting about hitting a switch... or turning on the ac... just a thought...
as far as having answers for everything i dont know bout that cus i ask one hell of a lot of questions...
what you can do is take out the mechanical fan and wire your electric one up to an igniton switch. there are 2 wires coming off the fan motor blue=power, black =ground. i've done this mod and sensnce the heavy stock mechanical fan is removed it has the same efect as installing lighter pulleys i havnt had any overheating problems from this mod but if you do it make sure your electric fan works and keep an eye on your temp gauge.
i did this with my car and left the stock electrical fan wired as it was... it works fine but i have not driventhe car... just left it at idle for an hour and no over heating...one small thing i dont like... my water pump makes noise now... and it is driving me nuts... it is as if i can hear it pumping when i am standing outside of the car with the hood up...
it came with an electric fan yes... and the clutch fan... mine is still hooked up factory... and it works kick *** i let it run lastnight to charge the battery after doing all of my fog and headlight work... ran for bout an hour and a half... no over heating at all...i think mine was the ac aux electric fan... both of my 240's had em...but they are hooked up just like the factroy... if you want i can take pics of it... just let me know...
Originally posted by drnovascotia
Well answered everyone
Many people do this and get a fan or two. I myself had 2 10" Sentra fans, this 240sx i'm gonna get a 3.8L taurus fan.
Dr.
Dr.
#29
wikd did u get the pics??? its aight dont rush...whenever u get a chance....n i just realized that i dont have a clutch fan so im stuck on where to hook up the electrical connections. i think i have to do it by switch.
#30
i was meaning the stock clutch fan... the one on the water pump... i will get the pics tomorrow... i need light for my cam to work... i should be off work in time to have some light... i will also see if i can get pics of the electrical connections and where i have things hooked up for you... if not i can give you some suggestions on where to wire it up at...
