Confused about S13 SOHC ECU code
its some emissions stuff. i just electrical taped that sensor and put it to the side once i removed all of my emissions equipment.
bro just really check ALLLL of your connections. physically check all vacuums and hoses for cracks, you cant see them sometimes, but you will feel them. if you can swap out for a working ecu to see if thats the source of your issue.
YAY! well i replaced that MAF with that tiny sensor beside it from like 92 Stanza from junk yard looks like that problem is gone ) thanks for everything man i really do appreciate ya!
you don't have to buy the exact same one just make sure the gauge is a good quality one.
You may want to check your TPS. It sounds as if the placement in degrees to the TB could be off so that you might not be getting a decent ratio.
You may also want to check the IACV as it can cause issues with low idle.
A bad MAF as BIGG said could pose those problems as well.
Check your injectors the O rings could be bad.
The vehicle speed sensor can cause slight issues with running rich on OBD1 engines so you should try to get that fixed.
Just my 2 cent's.
Just my 2 cent's.
If you are throwing a code 14 on a 1990 or a 1991 240sx, the engine will run richer than normal. I would get speed sensor fixed.
As far as the tach being screwed up until warm I would check relays and tach one or the other could be bad.
well im still throwing code 14 and the change of MAF helped only for 2 days now i have the same problem again - the car barely starts from 1st try, like I said the whole car shakes as a ****, but then after second try it starts and runs really good
I AM RUNNING RICH since i have installed that OBX header along with muffler shop special 3" exhaust, but with brand new Cat. converter. But, the car doesnt smoke or anything like that, just smells like gas a bit behind the car.
Spark plugs, wires, injectors, air filter - all of that i checked a million times so its not in my case.
I dont know guys. My speedometer seems to be working and Tach and the rest of that ****, have no idea why it throws code 14 !?!?!? BTW it is not cheap to replace that speedo sensor it its about 133 + shipping i checked on one of the web sites. Some people I was talking to saying the it might the FPR cuz it doesn't hold thee fuel over night so it goes all the way back to fuel tank - thats why i cant start the car from the first try, or some people say that this might be a weak pump that is about to go out, but i dont what to do right now cuz those things aint cheap and even if i replace it, what if nothing is gonna change so its just gonna be a HUGE waste of money.
AS FAR as people say here it might be:
1) FPR
2) Fuel pump
**NEW** Someone said today:
3) Speed sensor (even though my speedometer works fine)
Confused even more now ...
1) FPR
2) Fuel pump
I would pressurize the intake manifold system and listen for leaks.
2fast4y0u
03-05-2006 09:40 AM
