car wont start
i found a fuse broken in the fuse box next to the battery..on the cover its says FL75a/ALT could this be the reason y the car wont start? i tried lookin for another one in diffrent stores but noone has it..if i need this fuse is there a website where i can order it cuz i cannot find it...im gonna check the junkyards tomorro hopefully theyll have 240s there
ok i b ought the new fuse and put it in..the electrical started to work again but the car still doesnt work...i wanna try that starter trick mentioned before in the beginning but i dont kno where the starter is at and idk wat im lookin at
the starter thing is a pretty easy thing to do... look under the intake mainfold and looking straight back to where the tranny bolts up to the block... you will see the starter there... all you have to do is have a friend turn the key at the same time while you tap on the starter with a hammer or something.
the clutch switch kinda hard for me to explain so hopefully someone else can post up informantion for you.
ok heres the 411 on the car...brand new battery brand new alternator...and i did the starter thing and it turnd out to be the problem..however..brand new starter just installed...the car cranked over when i tried to start but it didnt turn on completely...i gave it a jumpstart thinkin mayb it mite be that but still nuttin..ne ideas of what it cud be...sumone thought it could be the sparkplugs b ut i doubt it cuz i had a tune up only a month and a half ago
sooo it turned out to be the starter when you tapped on it with a hammer or something.... so you got a new starter... and still having problems??? you install the starter right???, have the wires hooked up back right?
then search info on the clutch pedal switch thats behind the clutch pedal...
i kinda had the same problem actually... got a new starter and car still didn't start so then i ended up checking the swtich behind the clutch pedal.
#26
alright this is all i can tell you about the switch... your just gonna have to firgue it out while your looking at it....
If car is stick shift, check that clutch pedal is fully depressed. Check neutral safety switch behind clutch pedal (small button that prevents engine from starting when transmission is in gear). If clutch pedal doesn't fully engage neutral safety switch, engine will not crank.
or pretty much the last thing i can say is check the coil and coil plug
and here is a linky for moe help...
http://www.ehow.com/how_112584_troub...-car-wont.html
