Budget Mans Guide to an N/A Build
#32
well under idle, you will run a bit lean... becuase the engine is not asking for fuel at this point and time.
what kind of system are you using to tune.
if it helps i am running 370cc injectors on my turbo ka at about 8-10 psi with no issues at all and perfect A/Fr's
#42
ahh. see when I had my impreza, the pulley/ whatever set felt like it gave me a lot of extra power and the engine reved a lot faster. Thats why i mentioned it, but if its not a good idea, then i wont waste my money.
#43
lightweight crank pulleys do allow for quicker revs and result in noticeable throttle response, however they are not dampers. it's a catch 22 with lightweight undampened crank pulleys because they allow quicker higher revs. the problem is that once you reach the higher revs the undampened pulley can be detrimental.
lightweight accessory pulleys are not worth the money imo either.
#45
there two schools of thought on this and i am of those how believe that lightweight crank pulleys do not poses the necessary dampening properties that a stock pulley/ balancer has. the closer you get to redline the more stress is being placed on the crank by the pistons and what not. in a nut shell the balancer keeps the crank from vibrating to the point where something brakes.
like i said there are some who feel that what i've just said is just not so and i respect they're stand on the issue but i have by believes and stand by them.
