Bad Idle..Fuel Smeeling Smoke at the Exhaust
Old 05-09-2006 | 11:09 PM
ToRu's Avatar
OK....90 model. Starts & idles VERY rough, the motor shakes a lot.....will not stay running for more than a minute......large amount of smoke out the back....but not oil cloud...the fuel cloud...smells very badly of gas.
*pulled the codes....they read MAF, Idle Switch, Knock Sensor & a leaky injector.
My question: Would these make the car not run basically at all...or do I have a blown motor issue?
Question 2: Where is the Idle Switch & the Knock Sensor....I have a crappy Chilton & can't seem to figure out the diagrams etc...
please email me direct if possible lullaby@insightbb.com
Thanks Scot
Old 05-09-2006 | 11:42 PM
ReigH's Avatar
check your fuel injectors you might need to replace them
Old 05-09-2006 | 11:48 PM
def. could be an injector. First check your spark plugs and wires to check that your getting spark, if so do a compression check and see what you get outa that, to make sure all cyl. are good. If comp test is good, ignition is good, then you prolly need to check/replace your injectors.
240_baller
KA-T
10-12-2008 10:49 PM
2forties
09-09-2006 11:55 AM
1990sx
09-20-2005 07:30 PM
got2b240
06-20-2005 01:59 PM
nick3
05-22-2005 02:26 PM
