altima cams and 240 cams?
Old 10-03-2004 | 12:52 PM
240sx 5spd's Avatar
I read on ********** somewhere if putting altima cams in a 240sx willl add 22+ HP. anyone know about doing that swap?
Old 10-04-2004 | 05:43 PM
swannjay's Avatar
Altima cams won't allign with the 240 cam towers. Its been cleared up on Fresh Alloy.
Old 10-04-2004 | 08:46 PM
240sx 5spd's Avatar
then why does www.**********.com in the faq area say it works????
Old 10-05-2004 | 08:26 AM
djradam's Avatar
http://www.**********/faq/articles/cams.htm
Old 10-05-2004 | 03:16 PM
240sx 5spd's Avatar
What cams should I change my Ka with to produce more power affordably? 95 240SX SE
I have been tipped off that you can take the cams from the Altima KA and put them in the 240 KA. The duration is longer on the Altima cams than the 240. An easy 22Hp gain with direct bolt on. Find a wrecked Altima to get them from.
Sorry guys if I was miss leading before, Take the Intake cam from a Altima which is 248 Degrees and a exhaust cam from a 93 240SX which is 248 Degrees and replace the cams of the 95-96 240Sx SE wich are 232 degrees. This can be done with no more mods depending on the milage of your motor. OKAY.. SO IT STILL SAYS IT'LL WORK IF TAKING ALTIMA CAMS AND USING THEM ON A 240. BUT YEARS 95-96 BUT I HAVE A 92 SAME ENGINE AS A 95-96. SAME KA24DE ENGINE. SO CAN I DO IT?
smurphs_s13
04-20-2005 10:10 AM
GUNLINE
02-01-2004 04:40 AM
ChickenWing
08-08-2003 09:26 PM
cesar elkhabbaz
12-10-2002 10:42 PM
uofa240
12-05-2002 08:15 PM
