Turbo Setup - N60 filter kit? and FMIC?
Old 04-09-2008 | 11:10 AM
award78's Avatar
I'm planning on doing a t25 setup on my ka24de (7-8psi) and just need some advice. I have an N60 MAF but not sure what air filter kit would bolt up to it? I assume I need a sr compressor inlet that will connect to the maf with hose clamps but how do I connect the other end.
I don't really have access to a welder so I need something that will bolt up. Would this work:
http://phase2motorsports.stores.yaho...fuzepoins.html
Also, what mods are needed to use any S14 SR20det FMIC kit?
Here's what I plan on buying
370cc sr injectors - bought already
n60 maf - bought already
used t25 - bought already
phase2motorsport; mani/elbow http://phase2motorsports.stores.yaho...25tusekit.html
jvt downpipe http://phase2motorsports.stores.yaho...vt3fldosr.html
walboro 255 http://phase2motorsports.stores.yaho...25fupukit.html
top fuel bov http://phase2motorsports.stores.yaho...fuunbloff.html
jgs oil line kit
xs power fmic will this bolt up http://xs-power.com/nissan-intercooler-kits-1.htm
ngk irids will sr20 plugs work? http://phase2motorsports.stores.yaho...irrasppln.html
safc / aem uego / boost guage
Thanks
Old 04-09-2008 | 01:24 PM
1. you don't have to weld anything for the intake system. your t25 should have inlet and outlet adapters if not search around the web
2. all you have to do is order a filter kit for a 89-94 maxima it will come with the proper adapter that will bolt right up
3. No modification is needed to run the sr20 piping. because you have a t25. it will bolt up as if it was a sr20.
4. nothing will go as planned.. you will slightly have to modify something because no 2 setups are completely the same.
5. Plugs are generaly universal. just go into the store and ask for BkR7e-11 cold plugs for the KA. or you can get an single node plug and gap them your sell .028 to.033 or so.
Old 04-09-2008 | 03:37 PM
award78's Avatar
I guess I'll have to find the inlet and outlet somewhere.
thanks for the advice.
Old 04-09-2008 | 03:49 PM
no problem bro.. you will be able to find them easily on ebay.. forums or on someones desk as a paper weight lol... you be fine
Limited Slippin
03-17-2016 10:27 AM
BILLYhoang
03-17-2008 09:51 AM
Treyz
02-17-2008 06:59 PM
duncan351
12-14-2005 09:13 PM
yektik99
11-14-2004 11:42 PM
