Need Help Now!!!!
Old 08-11-2008 | 08:36 PM
240Boogyman's Avatar
Need Help Now!!!!
Ok guys. I have a problem. I recently rebuilt my ka24e for the kat project. I had my crank turned .10 over but didnt have anything done to the block besides a good cleaning. I bought .10 over bearings and put everything back together with all new internals. Well once back together the damn thing can barely be turned over by hand. I took it back apart and checked the clearences once more and lubed it up again but still the same. What do i need to do? Any help would be greatly appreciated. Thanks
Old 08-23-2008 | 08:16 AM
Evans1109's Avatar
Did you get this resolved, if so what was the fix?
Old 08-27-2008 | 12:55 PM
me and one of my friends took the motor back apart this past tuesday and found that everything was way too tight. I inspected everything and and found a high spot on a journal on the crank. I took my rods to the machine shop to get reconditioned and my crank to get polished. Just got everything back today and am planning on putting it all back together tuesday when my new bearings arrive. If everything goes right i will then be part of the ka-t world.
Old 08-28-2008 | 04:36 AM
did you use engine assembly lube???
Old 08-31-2008 | 06:50 PM
Evans1109's Avatar
Nice dude post pics when you get it complete, what is your setup?
Old 09-08-2008 | 08:05 PM
my setup is -
turbonetics t3/t4 - jgs turbo kit
z32 maf
apexi afc neo
innovate wideband
550 cc injectors
ebay fmic
autometer boost gauge
autometer oil pressure gauge
complete rebuild
looking at running about 8 - 10 psi to begin with.
Old 09-08-2008 | 08:08 PM
yes i used assembly lube.
dbgtdude
11-18-2006 05:10 PM
prospec240
02-05-2005 02:26 AM
driftindreams
10-24-2004 04:05 PM
driftindreams
10-10-2004 02:53 AM
ryan15
06-07-2004 12:49 PM
