More Reliable Ka-T ....
Old 09-15-2007 | 04:44 PM
  #46
S14_Turbo's Avatar
wow... i didnt know they had adapters.. the search begins !
Old 09-15-2007 | 05:03 PM
  #47
S14_Turbo's Avatar
oh its a .57 trim... is it still ok or too big also ?
Old 09-15-2007 | 07:36 PM
  #48
its fine
Old 09-18-2007 | 07:07 PM
  #49
S14_Turbo's Avatar
KA-T Stock Internals
How much can KA-T w/ stock internals take comfortably for daily driving ?
Old 09-18-2007 | 07:20 PM
  #50
Akuma240's Avatar
It can take 7 to 10 psi with stock internals.
Old 09-18-2007 | 07:42 PM
  #51
shaban's Avatar
All depends on your tune
Old 09-18-2007 | 07:46 PM
  #52
S14_Turbo's Avatar
6 to 10 lbs daily ? on lets say a t3/t4 with a 65mm trim ?
Old 09-18-2007 | 08:31 PM
  #53
there is never a definite answer. it depends on the condition of the actual engine in question, headgasket, compression, and oil consumption should be the main determining factors. and of course the tune.
Old 09-18-2007 | 09:14 PM
  #54
S14_Turbo's Avatar
so i should do compression test, monitor oil pressure, and sum thicker head gaskets maybe ? and i should be okay ?
Old 09-18-2007 | 09:17 PM
  #55
nightkid86's Avatar
do a comp test, get an oil pressure gauge, invest in a good tune. 6-10 should be doable.
Old 09-18-2007 | 09:28 PM
  #56
S14_Turbo's Avatar
It shall be done.. anything else to watch for ?
Old 09-18-2007 | 09:31 PM
  #57
WeS_R20's Avatar
6-8psi.......10 might be pushing it if its a daily
if you have the money i say first do the internals....
dont really know.....ive been through different problems here n there with friends cars n stuff.....its like playing russinnn rulet....
ask someone thats runing one really....
compresson test that bich, do a lil research, AND CHANGE THE PLUGS!!!!....lots of people forget.....lol
Old 09-18-2007 | 09:42 PM
  #58
i would do a leakdown test to make sure your valves are in check
Old 09-18-2007 | 11:22 PM
  #59
im running 10 but one day i left my wastegate line off by mistake and i was running 15psi.. my buddy like how much psi you running, i replied only 10. ... he said well your gauge is going up to 15 then i saw it and said OHH **** i dont have the injectors/timing mangagement for that. luckily nothing happen
Old 09-19-2007 | 10:02 AM
  #60
S14_Turbo's Avatar
hmm got a few tests to run then...what do i do if my compression in a cylinder is lower than it should be rated....
