How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
S13 Front Swaybar Install...for the noobs!!!
Old 06-24-2007 | 02:55 PM
positron's Avatar
When I started my suspension project I was going to get a new aftermarket front swaybar but since the stock endlinks were bent and missing on one side I decided to get new hardware and try out the stock bar's performance before doing so.
Tools needed:
Jack
Jackstands
Socket wrench
17mm socket
15mm socket
Stock front swaybar(25mm). I removed my stock front swaybar, cleaned the grime off and sprayed a couple of coats of black on. Looks like new.
The stock d-brackets weren't bent so I cleaned, repainted and re-used them as well.
New set of stock endlinks, they don't come with any hardware from Nissan. New Energy Suspension swaybar bushings. My old endlinks were in terrible condition, the passenger side endlink was bent up pretty good and the drivers side endlink wasn't even connected to the swaybar.
If you get a new bushing kit, use the supplied grease to lube up the swaybar where you put the d-bracket bushings on. Go ahead and put the d-bracket bushings and d-brackets on the bar.
Take the swaybar and slide it underneath the front of the car.
Insert the new endlinks into the top of the lower control arm.
The bushings and spacers on the endlink go in this order:spacer-bushing-control arm-bushing spacer bottom nut.
Tighten with the 15mm socket and torque to 14-22ft.lbs.
Insert the top of the endlink thru the swaybar...
put the washer and nut on, tighten with the 15mm socket and torque to 30-35ft.lbs.
Bolt the swaybar d-bracket to the chassis...
torque to 29-36ft.lbs.
And you are done!
Old 06-24-2007 | 04:43 PM
Where did you get those sway bar end links, and how much did they cost you? Did you go to the dealership? Autozone and Energy Suspension don't have them. I am doing the same thing right now and just cant find the links.
Old 06-24-2007 | 07:11 PM
coolness..........
Old 06-25-2007 | 08:52 AM
positron's Avatar
Nissan part numbers for the front swaybar endlinks: 54618-56S11 Endlinks sway $15.09 ea.
I got them from Nissanparts.cc but you can use that number at any Nissan parts website. They only thing is that they didn't come with any hardware like the three spacers, and the two link nuts. The ones on my original endlinks were either in terrible shape or missing so I went to a junkyard and pulled two endlinks off a junker 240SX and used that hardware.
Old 06-25-2007 | 10:13 AM
Thanks man. I just went to Advance Auto and they have the whole assembly, nuts, spacers, and bushings. I think it's a little more expensive though, like 21 dollars or something.
Old 06-25-2007 | 10:17 AM
nice write up man. i want you to put your car on a lift and take a pic. im sure a bunch of mulitcolored suspension parts would peek out. youve done lots of suspension writeups. lol
Old 06-25-2007 | 12:44 PM
Iwanta nismo's Avatar
looks pretty spiffy too =P haha
240driftfiend
03-07-2008 04:30 AM
positron
04-19-2007 12:34 PM
positron
01-24-2007 11:12 AM
krazieddi
Northeast
01-15-2006 11:57 PM
veilsides14
12-17-2003 04:59 AM
