Where does the Transmission fluid go? Dee dee dee question
Old 07-05-2007 | 10:14 AM
91240SXGuy's Avatar
I can't figure out where to put the tranny fuild on my KA24. I know dee dee dee question, but I need some help here. It's a 91 240SX. Thanx for any help! Peace
Old 07-05-2007 | 10:16 AM
The fill plug is halfway up the side of the bellhousing nearly parallel with the drain plug, on the passenger side, iirc. It looks identical to the drain plug. I assume you're talking about a 5 speed.
Old 07-05-2007 | 10:26 AM
91240SXGuy's Avatar
Thanx ryguy...you're the bomb nickel!
Old 07-05-2007 | 11:27 AM
actually if it is a 5 speed it's easier if you remove the shifter and fill it from there.
Old 07-05-2007 | 12:22 PM
you can also fill it through the shifter.
Old 07-05-2007 | 01:25 PM
WeS_R20's Avatar
some shifter action will work...try to go with some Royal Purple!.....its alot easier to put the fluid thru the shifter.
Old 07-05-2007 | 03:20 PM
well the reason i say that is.. i know people who have striped out the 1/2 square hole and only option was the shifter, which is easier...
also if you happen to mess up you drain you have three options.
1) remove speed sensor
2) remove drive shaft
3) weld bolt head or socket onto striped plug.
Old 07-05-2007 | 08:57 PM
Iwanta nismo's Avatar
cool never knew u can do that...i guess u learn somthing new everyday
Old 07-07-2007 | 02:11 AM
91240SXGuy's Avatar
Thanks everyone! Got it taken care of. Appreciate all your help/advice!
Old 07-07-2007 | 09:31 AM
YAY another satisfied customer..
Old 07-08-2007 | 02:16 AM
91240SXGuy's Avatar
Wink Wink, Nudge Nudge, Know what I mean...say no more...say no more! LOL!
portion
05-07-2005 04:40 PM
bw54867
03-18-2005 07:47 PM
sw20>>s14
01-18-2005 06:01 AM
Whisper
11-14-2004 04:53 AM
