Need help with heathing problems...
I dont knwo if this its like a 240 thing but i had a 92 and a 89 s13 wich i had the same exact problem with the one i have now, i live in mass, so it gets kinda to cold up here by winter time. and so far i have no other car but my 240. now i have a 93 s13, that it takes forever to warm up, i turn it on for like 15 to 20 minutes to warm up a lil bit, and the heat in the car its not as hot as i would like it to be its just warm, some ppl told me that its the thermostat, so i was wondering if its that or something else cuz like i said i had the exact problem, with my other 2 240's that i had thanks....
it could be that the thermostat is stuck open. i assume if you've been told what the problem might be they also told you how to check it so i wont go into that. a quick fix remedy is to get a piece of card board about the size of the radiator and slide in between the ac condenser and the radiator core. it's not the best solution but a quick one that will work until you replace the thermostat if in fact that is the problem.
[QUOTE=Biggamehit;378572]replace thermostat and bleed the system. QUOTE]
Don't forget this part. Had a friend that skipped that step and had a air pocket stuck in the line, lets just say he was overheating and then cursing in the end.
sirenx
09-03-2005 02:02 PM
driftndodge
02-05-2004 02:33 PM
