Door won't latch when I close it
Hello,
I have a '95 Nissan 240 SX. My passenger side door will not latch when I close it. Its not that the latch is down and needs to be flipped up the latch wont lock into place when the door shuts.
Is there anything I can do to fix this myself?
Thank you in advance!
my supra has the same issue. the latch got bent and is really old and wont go back into place i have to get a new one if you can get the latch out compare it to the other one on the drivers side if you can fix it gl if not i might be able to get one here at a junkyard
emoximuu
10-01-2006 12:52 AM
