z32 brakes- 26mm or 30mm, alum. or iron, TT or NA?
a few questions about the z32 brakes-
first of all, i have stock rims, so....
26mm or 30mm?
aluminum or iron?
from a turbo or non turbo z32?
are there differences between different years?
26mm or 30mm?
aluminum or iron?
Ideally you want the aluminum 26mm calipers. These will fit behind most stock 7 spoke S13 wheels.
If I remember correctly, these came only on the 1990 n/a Z32. After that the n/z went to steel calipers wich are heavier. All tt's had the 30mm (early were aluminum, later were steel), which will not fit without spacers.
-Justin
-Justin
wannaS15
04-12-2006 06:18 PM
rancidnsx
03-09-2005 12:54 AM
mmdb
07-03-2004 11:55 AM
badman70_1
16
03-01-2004 09:02 AM
