what parts from s13 can be used on s14
Old 12-31-2003 | 10:49 AM
GoldZenkiS14's Avatar
Arrow what parts from s13 can be used on s14
Hi, i bought a s14 with no interrior and i was wondering what parts from an s13 fit onto the s14?? The reason i want it from a S13 is because there are no S14s in the junkyard and im trying to rebuild as cheap as possible .. So far i know the front seats work, and thats about it.. I need to know if the ignition switch, the steering wheel air bag, the s13 MAF and the rear view mirror will fit on an s14 from s13 parts?? .. also if i buy a s14 MAF will the harness from an S13 work?? Please let me know i need to get this car up and running asap and need answers .. thanks for any help you guys can give me
Carlos
Old 12-31-2003 | 11:39 AM
Justin.b's Avatar
I don't think you will be able to use the S13 harness without modification. The S13 is an OBDI system, S14 uses OBDII and probably has some different sensors, possibly in different locations.
Try www.car-part.com and see if you can find the pieces you need. They're an online database of junkyards.
Not many S13's had airbags. I know the US hatch and coupe had those silly moving seatbelts as an active restraint. The convertibles may have airbags since they don't have anywhere for the seat belt tracks to run.
Sorry if this isn't much help.
-Justin
Old 12-31-2003 | 12:00 PM
WingsNThangs's Avatar
Seats.
irax
12-31-2004 01:28 AM
lrb_2000
10-27-2004 02:30 PM
lrb_2000
10-24-2004 10:54 PM
lrb_2000
10-22-2004 08:44 PM
PowderB16
09-23-2004 12:34 AM
