what octane should KA use 87 or 89?
#34
Originally posted by Chiefgmsr
So is agreed that 89 is the best octane to use? except for everyonce in a while when you should use 93 for the cleaners.
Also mandatory for oil changes, change your oil every 3000miles as recomended by the oil filter manufacturer. That will prevent oil viscosity build up, and loss in HP do to age and degredation of internal moving components. Do "NOT" ever use 5minute engine flush at you local auto store "kragen" to name a few, and they only sell crap anyway's that they claim is performance for your AVG. moron. The chemical compound in 5minute oil flush destroys the engine during the 5 minutes of idle rev, killing your bearing's and piston rings, also including damage to the valve train.
Yes; 89octane is only to be used on a stock "trim 240sx" unless you have either advanced your timing 4degress on the distributor for 91 octane, or had a performance rebuild with higher compression pistons, fuel injectors, etc...., or an engine management upgrade that will allow to dump more fuel,"other wise known as a rich fuel/air ratio.....
It is unecessary to use a fuel at any other rating, your not really hurting the engine on higher octane's, your just eating out your pocket bookMy 2 cen'ts.....
Where is Raine when ya need him on the fact's......
Just a reminder to you noobs buy the chilton's/hayne's manual that is the bible to your engine...........
#35
i own the chiltons, but in michigan premuim is 91 octane. so that could make sense then if your premuim is 89. but our regular is 87 and our silver is 89 and premuim 91. so then should i just use silver (89)? what does 87 do?
#36
you need to use a higher octane if you have a high compression motor or force induction and engines perform best at a certain octane. goif a engine is designed for 89, then it'll work best with 89. doesnt mean putting 91 will make it better
#38
weither or not if 89 octane is called silver "in very few U.S states" or premium "in most u.s states", it is still only 89 octane that you are to use for all stock trim KA24de's. "Almost" all cars manufactured in the U.S since about 1987 have been built to the California smog emission standard to simplify the production line of the vehicle's.......
You will also notice this manufacture type of production when you read your chilton's/haynes manuals.
#39
Originally posted by jackyliem
so how about sea foam. is it one of those 5 mins flush as BigVinnie said? or is it better?
#41
I run 87 w/o any problems.
But then again you have the 91-94ka24de engine which has the lower of the 2 compression ratio's I believe 8.5:1?
That to me is a "border line" regular 87octane engine, you also have to keep in mind that the factory advancement in timing is already preset at 20 ATDC, believe me you will do better on 89...
#42
Well, I don't run the hell out of my engine or keep the revs up too high. The highest I ever continually rev it at is 4k on the highway is anythng. It doesnt ping at all and runs just fine. It also has 76k on it if that means anything.
#43
so what about the ka24e? i now know that the ka-de is best for 89 but is the ka-e the same with its lower compression?
this is fun im learning all kinds of new stuff i never even thought about! thanks big vinnie.
#45
Originally posted by chiroke
octaine??? the higher the better i always use 93 and if i dare find 98 in NYC man ill go there
Geez some people are just born stupid. Shiat like this is F@#KIN' up my thizzle high RIGHT NOW. If you wan't to be dumb and add higher or lower fuels that is your perogitive..... But don't preach you negative uneducated opinion that it is alright to use higher octanes, you are not helping the performance, so you might as well buy the "correct" cheaper fuels.......I swear too many teenagers in these forums that really don't know jack about engines. I bet almost none of you read your repair manuals.....
