what octane should I use?
Old 09-18-2006, 04:48 PM
240's"r"us's Avatar
gas just dropped five more cents hopefully it will go down 14 more cents and ill be gettin gas 2.00 a g
240's"r"us is offline
Old 09-18-2006, 06:57 PM
Banned
2forties's Avatar
Damn that is hella cheap!!! Why cant Cali gas be so cheap?
2forties is offline
Old 09-18-2006, 11:50 PM
Waynehead05's Avatar
well i know an s13 ka dohc is designed for 89 octane. i'm not sure if premium gives you any better mpg, but i just use 87 or 89.
Waynehead05 is offline
Old 09-19-2006, 12:07 AM
yea id run 87-89 for ka assuming its stock....sr needs the highest you can get, unless its like 100 or something, basically 93-95 would be best
motegineon is offline
Old 09-19-2006, 12:21 AM
KAMAKAZI 13's Avatar
damn i wish i had 100 around here.
still 40 bucks to fill my tank.
KAMAKAZI 13 is offline
Old 09-19-2006, 05:01 AM
Its hard to find 100 in NJ, unless you go to the racetrack. Then they have 100 105 and up
Im just happy prices are going down FINALLY (hopefully they keep decreasing)
RuizXIII is offline
Old 09-19-2006, 06:54 PM
Darkvillin's Avatar
what makes you say an s13 ka dohc is designed for 89. it clearly says on my gas door to use premium 91 or better and the same in the owner's manual. just curious, not trying to be nit picky. i used regular 87 once. the engine sounded like garbage. it was so choppy going thru rpms and i had no power. with 91 it is very smooth and a quick lil car.
Darkvillin is offline
Old 09-24-2006, 06:19 PM
bombinha's Avatar
Another thing not mentioned here is I've tried to run on 87 sometimes and I always end up getting the check engine light for knocking sensor and or O2 and this happening because some gas stations are mixxing up the fuel and not even getting 87 anymore and less than 87 you will have problemas so think about it as a ping on engine can be a lot more costly.
bombinha is offline
jackyliem
05-16-2006 05:01 AM
nightkid86
01-22-2006 07:20 PM
Carparthookup
09-19-2005 07:34 PM
bcvjj21
11-09-2004 04:20 PM
S13freak
04-02-2004 04:58 PM
Quick Reply: what octane should I use?
