wft mafs and reprogrammed ecu
I have found alot of items that say z32 mafs and i have heard that in-order to use the z32 mafs you would have to have the ecu programed. is this true? most ecus that i have found are around 600. would i run into problem if i just put on the mafs and a intake kit that is designed for the the z32?
Umm you'd have a check engine light and probably run..lean.. or rich.. I don't know.. most people just get a piggy back system.. you don't need a z32 maf until you maxed out your ka24de one.. which is probably around 250hp..not sure.
Originally posted by advanced240
are u saying that i will only see gains with the stock mafs and not with the z32 wothout reprogramming my ecu?
valencia_ryan
02-08-2005 08:49 AM
thirden
11-08-2004 06:09 PM
kcolyer27
10-26-2004 07:42 AM
