turbo timer no power...
Old 08-19-2008 | 05:21 AM
slowpokee's Avatar
hey guys i just recently installed my turbo timer,
but the problem is theres no power..
and another problem is that my head unit is getting no power either...
and my ignition doesnt work... as in when i turn the key to start it doest.. i only hear the relays clicking
this whole no power to the dash happened after i did my sr swap... it was working perfectly fine before..
i checked the dash connectors nd it seems to be fine...
so im wondering what's the issue here?
Old 08-19-2008 | 07:11 AM
FuriousZ's Avatar
I am assuming you have no alarm system.
I don't know much but try a different relay. and of coarse check the connections.
try bypassing the relay. at least to try start the car.
Old 08-20-2008 | 02:28 AM
slowpokee's Avatar
no i dont have alarm...
but how do yu bypass the relay?
im sure my connections are fine triple checked them yesterday..
Old 08-20-2008 | 03:32 AM
1. when you wired up you turbo timer, did you use and quick connector.
2. if you didnt use a quick connection like me, did you test the voltage at the different positions ( ACC and ON)? they raise and drop and if you got the wrong one hooked up the signals will be all messed up.
if you didnt you probably screwed some things ups
if you did an sr swap into your car and right after you dash didnt work.. odds are your car was sohc and or you did the swap with the battery hooked up and blew something and or you didnt wire the body harness connection up.
you dont want to bypass any relay you wanna fix the issue and or you will have a fire for sure.
Old 08-20-2008 | 12:58 PM
slowpokee's Avatar
quick connector as in the turbo timer harness?
i dont really get what yu mean...
well my dash does work..well here's the things that does...
-cluster except the speedo, it jump up to 10mph when i put the car on the on position and stays there til i turn the car off
-my climate control light comes on
..other then that nuthing works...
my clock would restart once i open the door..
-my old motor was a dohc
during the swap i didnt hook it up to anything til i was sure that i was done nd all wired up already
and yes i agree bypassing doesnt sound too safe to me...
Old 08-20-2008 | 06:30 PM
there is a connection for the turbo timer. it allows for plug in play
i didnt use it becuase i am good with electronics and didnt need to waste the 15-20 dollars on it.
Old 08-21-2008 | 04:05 AM
slowpokee's Avatar
oh well in that case yea i did use the "quick connector"
Old 08-21-2008 | 08:28 AM
FuriousZ's Avatar
I don't know much about this but if the relay is used to contol the ignition wire, Like an alarm's relay,
I was thinking you can bypass the relay just to see if the car will start.
If it does start with the relay bypassed then it has to be the relay or something that controls the relay.
But If it doesn't then its something else.
Just trying to help ok guys.
Old 08-22-2008 | 02:58 PM
slowpokee's Avatar
oh ok i get what yu mean FuriousZ.. thankss
another problem that i have is that when i start the car for under 5 mins and i turn the ignition off, the lights on my dash would still be on...
but longer then 5 mins it'll turn off normally..
what can that be?
Old 08-22-2008 | 10:05 PM
Evans1109's Avatar
What wiring modifications have you completed? If you altered any of your wiring did you solder of use connectors/ taps? Have you checked your fuses? From the sounds of it somtheing maybe grounding out causing a relay or two to be sticking.
Old 08-24-2008 | 06:28 AM
slowpokee's Avatar
^^^^^^^^i guess the only i have is to check the grond wirings...
thanks =]
Old 08-25-2008 | 08:50 AM
Evans1109's Avatar
No problem man, but if it they are ok post up how you connected your wires and also aftermarket electronics.
Old 08-31-2008 | 12:03 AM
slowpokee's Avatar
what wires are we talking about here evans1109?
from what i read im guessing that yu mean how i connected my turbo timer?
if so then i just bought a turbo timer harness and just connected it like the instructions say...
if i'm wrong can yu correct please..
Old 08-31-2008 | 09:16 AM
Evans1109's Avatar
http://home.scarlet.be/broekmans.evi...bo%20timer.pdf
Check that link out and ensure your wires are grounded and ebrake wire is properly connected.
Old 09-02-2008 | 09:09 PM
slowpokee's Avatar
^^ wow that's a nice write up..
thanks
-HyJynX-
12-06-2003 01:05 PM
bztech
11-24-2003 10:55 PM
nisno
08-20-2003 04:50 PM
I'm with Stupid
06-03-2003 08:48 PM
j92s
05-25-2003 02:11 PM
