turbo timer install
Do you have a harness? If you do it's simple, you just drop the bottom dash that's above the pedals. You should see a big connector under there and you just un plug it and plug in your harness and you're done. Other than that you need to hook up the the E-brake wire if you have one...
bztech
11-24-2003 10:55 PM
