trunk rattle...
trunk rattle...
sry for the spam.... but my trunk is rattling alot and i dont even have a sub does any one know how to fix this problem if so plz tell me or email me the step on how to do it thnx a lot
another thing my trunk doesnt shut tight...like if i press down on it i can feel the trunck move down
Re: trunk rattle...
And post in the right section next time... this has nothing to do with audio.
to remove trunk rattle you do as follows.
1. loosen the bolts holding the trunk latch to the body of the car.
2. move the lack down about 1mm or so.
3. tighten bolts back up
this will cause the trunk to close and pull tighter to the body if this dose not help you need to do some real work to get the seal right.
this sounds kinda dumb but this is what i did. i went to the local bicycle shop and bought a set of real cheap handle bar grips that were soft rubber like material. i cut them about an inch up from the closed end and pushed them on to the rubber stoppers for the trunk...hasnt rattled sense then. worked like a champ and you cant even tell that they are there cause the are bleck rubber just like the factory ones. ill post a pick here soon.
its either that or you need to adjust the locking mechinism. just undo the bolts a little and move it. then retighten
and yes thats pretty much what i did. you cant ever tell that they are there. its pretty nice
battosaii930
01-16-2007 09:12 PM
