ticking noise
ticking noise
yes i'm have unlimited problems with my s13 single cam.....so theres a ticking noise....and some times it's real bad and at others it ain't so bad..you can here it when i accelerate ...i'm not too sure what it is....but it's coming from the engine area
when i suggested low oil pressure i wasn't referring to the oil level. there may be a relation between the two in this case but that is not always so. low oil pressure can be a result of a number of things that range from a simple and fairly inexpensive repair to a complete engine rebuild.
vinnie mentioned a bent valve and that too is a possibility. so to rule out one or the other i'd do a compression or leak down test and check the oil pressure as specified in the fsm.
