stripped screws
yeah the screws in my headleads were stripped and i came up with an easy solution. I got some pliers (needle nose in this case) and just slowly turned the screws until they came out. It took about 15 minutes for each screw but they came out. eventually.
Drill the heads off all the bolts. then remove the speaker. Once the speaker is out you should be able to grb the threads of the screw's with a set of pliers. Do this buy going through the speaker hole so you grab the long bottom side of the screw.
LA_phantom_240
01-29-2006 01:31 PM
