Scratched window tint
Hie, I have a 96 240sx. I recently tinted my car. However a vertical scratch started forming once i kept bringing my window up and down. I talked to the guy at the tint place and he said I had to change something inside the door. Would someone know what it is? and where do i find instructions on removing my door panel? thanks.
If i'm not mistaken, there is a bolt or two in the Jam, and one near the handle. After those are out, just pop the panel off.
Pretty simple to remove.
There could be a bent rod or something internal that is out-of-place.
When you take the panel off, roll the window up and down, it shouldn't be very hard to see what is causing the scratch.
good luck
good luck
