S14 foglights
Old 06-17-2005 | 06:20 PM
Thanats's Avatar
S14 foglights
How do I get of the yellow lenses from the foglights.
I already tryed puttinng them on hot water, it suposed to removed the glass cover, but it didnt.
is there another way?
Thanats
Old 06-18-2005 | 12:06 PM
Slidin240's Avatar
heat them in the oven for like 10 min at 500 degrees. keep an eye on it so it doesnt melt. as soon as you take it out (becareful its VERY HOT) remove what you want and you have about 20-30 mins b4 the glue dries again.
BTW try not 2 get the glue on anything its a Bit<h to get out
Old 06-18-2005 | 01:05 PM
did you pm me a while back? im suprised the boil in water method didnt work. 500 is way to hot they will def melt in the oven that high temp. preheat to 400 cut off the oven place the light on a cold cookie sheet and put tin foil over the lense. wait 10 mins and try that. when u put them in hot water did you leave them in for like 5 mins? get a butter knife and cut the glue between the housing and lense and pull the sucker off. hope this can help also if the actual projector lense is yellow then you can not drive w/o and proj lense. you will need a clear lense otherwise you will have very crappy light distribution but if the yellow is just a little flat glass piece behind the projector you can take it off and be just fine.
Old 06-19-2005 | 11:10 AM
Slidin240's Avatar
i havent done this in a while, thought it was 500. sorry bout that. Good luck gettin it off.
Old 06-21-2005 | 07:31 PM
Thanats's Avatar
I did try for a bit more than 5 min. But with the oven its way to risky for me. Thanx for the help.
moo moo
12-05-2005 04:51 PM
Thanats
03-27-2005 09:37 PM
d4vech3n
01-08-2005 02:08 PM
Tko21
03-09-2004 05:48 PM
PROJECT_D
12-21-2003 02:14 PM
