s13 p/s leaking
s13 p/s leaking
my powersteering has been leaking pretty bad. like wen im parking i notice a lot of fluid on the ground. wen i ope the hood its all over where the powersteering resevior. i tried checking it myself. wiped up everything and tried looking while running the car. looks like it leaks right where the pump is but was curious why the pump would leak. anybody have a powersteering leak before. just want to know if anybody else has this problem b4 i go and buy parts...so lmk, thanks!
there are only 2 lines right? 1 going to and from the resevior and vise versa to and from the pump? also if its not the lines....and it is the pump any good places to get one? or just go to a local parts store?
any way whats a bango bolt??
wel it is comming out from one of the lines going to the pump. where the metal connects to the pump. would i need something like this to replace the bango bolt??
http://replacement.autopartswarehous...%20Kit&dp=true
