Quickest way to 12.5 1/4 mile times? RB20DET, SR20DET?
Old 10-19-2003 | 07:03 PM
EvilCerealBoX's Avatar
Originally posted by fist
if i wanted a V8 i'd get a camaro or a mustang....impala ss...
but you did say you wanted the quickest and least expensive way to 12s... and i gave you the answer to it...
Old 10-20-2003 | 04:17 PM
fist's Avatar
he also noted sr20det and rb20det...meaning a choice between the 2 of those engines.
Old 10-21-2003 | 10:27 PM
Re: Quickest way to 12.5 1/4 mile times? RB20DET, SR20DET?
Originally posted by brandonl311
I want to do a swap on my 240, and I want to achieve a 12.5-13.0 quarter mile time. What engine swap would you do to get up there cheapest?
in the title he was just listing engines, he didn't say we had to choose...
Old 10-22-2003 | 07:48 AM
fist's Avatar
ok here.....here's my question..
which engine of these three would be the cheapest way to get to 12.5 1/4 mile times? SR20DET, RB20DET, or RB25DET??
also without heavy modifications
Old 10-22-2003 | 08:21 AM
drnovascotia's Avatar
you'd have to do some tuning to get a sr20 down to mind 12's, so I think that rules it out.
I'd go RB25, but I don't know how much more it would cost to get that clip than a RB20.
Dr.
Old 10-22-2003 | 10:03 AM
Hmmmm...o0k well ima throw out sum prices..to get a RB20 shipped is roughly 2100..and to get a RB25 shipped is roughly 4100.
RB20 can run high 14s stock and RB25s can roughly run low 14s to high 13s
Get the usual I/E and tune it a lil..that will be..800 bucks roughly..
On the RB20, Get a New turbo..t3/t4 probably..and then pump up the boost to 18-20 psi (make sure the turbo can handle it)..and u should be pretty close to mid 12s if u got the right suspension set up , that mod can cost..2gs right there (guessing)
On the RB25, up the boost to 15 and tune it out..and u should be hitting low 13's and possibly high 12s, if u got the right suspension set up maybe mid 12s. 300 bucks for boost controller
RB20 pricing: 2100+800+2000=4900
RB25 Pricing: 4100+800+300=5200
These numbers arent very accurate but they give u an idea, now this does not include install cost or extra lil parts u might need. A plus for going for the RB25 is people have played around with it and know it more then the RB20..RB25 can supposedly hold more power then the RB20..and probably more psi on stock internals. Well all this should help u out
Old 10-22-2003 | 07:06 PM
fist's Avatar
that was an excellent reply..
will the rb20 and rb25 fit in as easily as the sr20?
Old 10-22-2003 | 09:29 PM
Thx..my times might be off a lil but u get the idea.
The RB20 fits in with lil mods, its pretty much just as easy as the SR20 swap, but mounts will be heplful (unstable hybrids make RB20 mounts). But the RB25 is a lil harder, u need a custom driveshaft and mounts will be helpful. (both can be baught from mckinney motorsports)
twofotisx
07-09-2007 07:15 AM
ANVIL
05-11-2004 01:32 AM
ryan15
12-16-2003 01:29 PM
s13stillen
04-26-2003 10:54 AM
drifties151
10-12-2002 12:43 PM
